Home > Technical > Loud clunk when making hard turn |
coke-poke Member Since: 31 Mar 2022 Location: Boston Posts: 1 |
Next up, we've got Live Jasmin, or as I like to call it, heaven on earth. This site has some of the most stunning babes you will ever lay your eyes on. Seriously, mate, these girls make me weak at the knees. And the best part? They're all professionals. They know how to put on a show and make you feel like the king of the world. But be warned, this site isn't free. However, with great quality comes a price, and trust me, it's worth every penny.
https://camanal.net/chat/jessica_gill https://theadultcams.com/fit https://camtrans.net/kinky https://bbwwebcam.me/chat/margaret_jones1 https://hotfreesexcams.com/saliva Last edited by coke-poke on 31st Jul 2024 4:46am. Edited 1 time in total |
31st Mar 2022 11:52am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2029 |
Have a look at your A frame ball joint, it’s connected to the rear axle just above and to the left of the rear diff when viewed from behind..
Some pics here in this topic https://www.defender2.net/forum/topic79508...ball+joint. If it is that you should not drive until fixed. Also best to get the new Ball joint fitted to a new housing, plus new bolts and nuts ( note get the right size bolts / nuts for your vehicle as they changed) as it’s not that expensive and removing an old and fitting a new ball joint into an existing housing is hard and requires 10 plus ton press. Not a USA site but this link should help identify the item. https://gwynlewis4x4.co.uk/product/a-frame...ng-gl1041/ Or https://gwynlewis4x4.co.uk/product/a-frame...inc-bolts/ If not the A Frame ball joint check all the rear suspension bushes To test your A frame ball joint I read this post on another forum. “the way i check for play in the a-frame is with the vehicle on the ground get someone to rock the wheels at 3 and 9 o'clock as if you are checking wheel - bearing play, this will show play in the a-frame, also with the handbrake applied rock vehicle back and forth while laying under neath and you should see any movement present and this will also show play in the link arms too.” In principle this seems a good way to visually check the movement of the ball joint and A frame bushes. Just make sure you are on a flat surface, the handbrake is working and is applied. Do others test the A frame ball joint and bushes this way ? Has it been successful in showing / identifying A frame issues ? |
31st Mar 2022 12:36pm |
