Home > Maintenance & Modifications > Larger / add on Fuel Tank 2.4 Puma
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Anyone installed done of these?
Looking for option without installing pumps and switches
https://www.flatdoguk.com/long-range-fuel-...to-8a~1533
Post #765323 25th Mar 2019 3:26pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Yes, I have one on mine.
Gives about a 100mile extra range capacity.
Regards Dave
Post #765343 25th Mar 2019 5:18pm
2010Blackdefender90
Easy to install?
Post #765348 25th Mar 2019 5:37pm
leeds
That tank is for a 90. Please note there are 2 versions so TD5/early TDCi is 50mm pipe and later TDCI is 60mm. Please check VIN number to ensure you get right tank.
Have a look here Whistle
Best to allow a decent amount of time, say a full day so you have plenty of time to do it. They can be fitted in about 4-5 hours. Start with minimal fuel in the tank. Fiddly rather then awkward is fitting the balance pipe. Need to drill a hole in main tank. Thread stiff wire through and fish it out via main filler hole. A fitting needs sliding down the wire and fished through the drilled hole. Hope that makes sense.
Brendan
Post #765361 25th Mar 2019 7:28pm
leeds
For a 90 there is no larger replacement main fuel tanks available unlike for a 110/130.
For a 110 it is possible to get a 120 litre replacement main tank plus a 48 litre wing tank. With extra pumped cill tanks on a 110 possible to get about 330 litres of fuel in tanks.
Please note with these large replacement tanks no tank guards are available but the bottom can be double skinned. Also they are not compatible with standard towing equipment but they do work with 2" receivers which are not approved towing equipment.
HTH
Brendan
Post #765402 25th Mar 2019 10:09pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
In all honesty, I wouldn't bother unless you want to put a LOT of time and effort into it for very little reward.
They are an absolute PITA to fit, the figures quoted for the capacity are total, not increased, and the tank replaces the original filler pipe that holds a good amount of fuel already. We found ours gives us around an additional 20 litres in real world use, the 30 litres is very much a theoretical figure of what the tank could hold in total. In practice the shape of the tank and the fact it removes the filler pipe that already holds around 5 litres results in 20 litres extra. The filler is below the top of the tank so actually completely filling the tank with a normal fuel pump is almost impossible and the biggest cross sectional area is at the top and it air locks.
After 3 years, ours sprung a leak at the back of the long section in the wheel arch. We're currently having to only partially fill the main tank as a result until I pluck up the courage to remove the thing and bin it. I need to replace the pipes that installation requires you to cut and find the original filler pipe first ! If you do get one, keep that pipe somewhere safe !
The tank comes with a very poorly treated/coated steel "guard", the paint/coating on ours had pretty much gone altogether after 6 months, really bad quality, same with the bracket that holds the front part to the tub. If you do fit one, strip off the coating it's supplied with and paint it properly with a decent zinc primer as painting it afterwards isn't ideal.
If you use the vehicle with larger than 30 inch diameter tyres and use the vehicle off road, the tyres will catch/rub on the tank, that may be why ours cracked. I'll know for sure when I remove it.
Fitting an additional tank under the driver's seat is actually much cheaper and gives you far more capacity. We have both and I'd not bother with the "long range tank" again. From memory, adding the second tank under the driver's seat cost around £250 including a galvanised tank guard and all the fittings including a changeover valve and gives around 55 litres extra fuel versus around 20 litres for £300. Alternatively, a 20 litre jerry can gives you the same benefit for a fraction of the price ! http://www.yorkshireoffroadclub.net/
Post #765406 26th Mar 2019 12:23am
2010Blackdefender90
Thanks, I wanted to avoid the Jerry can route, so this options seems a lot of hassle.... having done 3 runs into France, Italy, and Croatia, just wanted to look at other options, guess I will have stop more often.
Post #765472 26th Mar 2019 1:22pm
R1200GS
Had mine fitted by Challenger 4x4 in Aldershot before driving to Croatia last year. I know its a cost but it does make life
a lot easier and less smelly than jerry cans. They also changed that small breather pipe that perishes after three years or so for a decent one.
Plus you never have issues with jobsworth Customs guys who decide to levy taxes on 'Additional fuel cans', although that
depends on how far you intend to go Mr. Green
Post #765499 26th Mar 2019 4:18pm
2010Blackdefender90
I took a Jerry can on the roof and yes, the Croatian toll booth takers busted me too, twice, over height. Thumbs Up
Post #765506 26th Mar 2019 4:30pm
R1200GS
Another point is that on my Puma the seat box of the drivers side is full of fuseboxes and electrics so its a bit different
from Davew's one i think.
Post #765514 26th Mar 2019 4:51pm
davew
Mine also had an engine ECU, fuse box and wiring looms under the driver's seat so I moved them out of the way first as that also improves reliability for wading and reduces the risk (on a TD5) of oil in the loom getting to the ECU connector. http://www.yorkshireoffroadclub.net/
Post #765519 26th Mar 2019 5:14pm
R1200GS
Thats a lot of work to move. Well done. Beyond my electrical skills unfortunately.
Post #765535 26th Mar 2019 6:38pm
davew
Not sure how much of a job it is on a Puma, on the TD5 you have to extend 3 wires (difflock switch, hi/lo switch and hand brake warning) but other than that it's just a case of rerouting the wiring looms. http://www.yorkshireoffroadclub.net/
Post #765578 26th Mar 2019 10:39pm
Naks
I've had the Frontrunner one installed since the vehicle was bought new in 2010. Not a single issue or leak since then.
Every now and then I fill it up, put in a bottle of diesel cleaner and use it to keep the pump lubricated. --
Post #765668 27th Mar 2019 3:24pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi Davew. Where did you relocate the ecu etc when you moved them out from under the seat? Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #944496 3rd Mar 2022 7:49pm
