Home > For Sale & Wanted > [Wanted] Td5 Defender R380 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17419 |
Apart from the gear lever gubbins is there a difference between a Td5 Defender and a Td5 Disco R380?
If not it might widen your choices, Discos seem to be commonplace. |
14th Feb 2022 7:14am |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
As blackwolf suggests, a TD5 disco R380 can be used with one of the selector conversion yokes.
It's a bit of gamble buying secondhand gearboxes as you can't really inspect the internals without stripping it down. Why not rebuild yours? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
14th Feb 2022 7:30am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2231 |
As a heads-up. My V8 90 has a Discovery R380 in it with an Ashcroft adaptor for the selector shaft and an LT77 top housing.
Gearchange in the donor discovery was really nice and slick. Gear change in the Defender is horrible, struggle to get it into 5th or reverse some days and when it gets hot even 3rd is a struggle to find. No idea why as they all select nicely when static and there is no adjustment possible on it. If I was doing it again, I would fit the whole defender selector rail shaft instead and have a good look at the condition of the rest of the box. Steve 02' 110 TD5 Double Cab Rebuild Thread |
14th Feb 2022 8:06am |
