Home > Technical > Webasto blowing only old air |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
These heaters are pretty simple overall but the fuel supply is often the problem or dirty glo plugs.
Webasto's if not installed correctly will not light up ... the "Common" issue is the fuel stack pipe from the tank not being correctly fitted. I'd look at the fuel supply for ignition or if its an older unit then not serviced glo plug wise. Good luck John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
29th Dec 2021 12:13am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 636 |
I had problems with Webasto fuel pump blocked by slime from bio part of diesel. Pump was not clicking and delivering fuel. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
29th Dec 2021 7:13am |
