Home > Td5 > HELP! Oil Filter Housing Haemorrhage
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
HELP!
Chaps, my Td5’s oil filter housing gasket had a leak. I’ve pulled it all apart, replaced the gasket, and put it back together. It then started to haemorrhage oil from the gasket. So, I did it all again and used another gasket. Both were genuine LR. Both leaked from the same place.
It’s such a bad leak the vehicle is essentially immobilised.
Have a look at the photos for the source.
Where am I going wrong here?
Are the gaskets bad? Is there damage to the housing? Am I missing something out?
All and any suggestions would be very gladly received!
 Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #935158 26th Dec 2021 3:36pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
The housing for the oil filter has a pressed steel gasket.Did you change that?
Marc.
Post #935162 26th Dec 2021 4:27pm
BaronDefenders
Yes I did, Marc.
Used a genuine LVH100230, which failed. I then tried another genuine one, which also failed in the same spot. Charlie
2002 Td5 90 (SOLD)
Post #935163 26th Dec 2021 4:29pm
sharkey964
Mmmmm,is the engine pressurizing somehow?
Or,the oil level too high?
Marc.
Post #935167 26th Dec 2021 5:13pm
BaronDefenders
Oil level is fine. Cold idle pressure was 3.5bar when I started it up earlier.
Just can’t understand it. Charlie
2002 Td5 90 (SOLD)
Post #935186 26th Dec 2021 7:00pm
BaronDefenders
I think the problem has been identified . . .
Cracked housing by the bolt. Charlie
2002 Td5 90 (SOLD)
Post #935212 26th Dec 2021 9:37pm
sharkey964
It's allways good when you find the cause of a problem. Thumbs Up
Well done.
Marc.
Post #935236 27th Dec 2021 7:38am
BaronDefenders
New housing on order, so fingers crossed that will sort it! Charlie
2002 Td5 90 (SOLD)
Post #935247 27th Dec 2021 9:01am
BaronDefenders
As expected.
 Charlie
2002 Td5 90 (SOLD)
Post #936675 7th Jan 2022 8:56am
sharkey964
Well done.... Thumbs Up
It's great when you find the root cause to a problem.
Marc.
Post #936697 7th Jan 2022 11:59am
BaronDefenders
Very satisfying to find, I must say! Charlie
2002 Td5 90 (SOLD)
Post #936699 7th Jan 2022 12:08pm
