Home > For Sale & Wanted > [Sold] National Luna portable power pack
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
National Luna portable power pack with 11Ah leisure battery - £200
Pretty much 1 of these with the battery already installed https://www.nationalluna.com/product/porta...-hardware/
Appears to retail around £350 without the battery for the limited stockists in the UK (APB trading)
The Portable Power Pack features fused accessory plugs, a polarised high-power plug and built-in battery monitor with low-battery and over-charge warnings. The built-in plugs can be used for low-power accessories such as refrigerators, pumps, compressors, lights and other 12-volt electronic devices. The high-current input-output can be used for higher power requirements such as invertors or battery chargers. The built-in split-charge isolator is fully automatic and does not require additional hardware in the application vehicle.
Split-charge isolator built-in
Integrated battery monitors
Dual 2.4A USB charge ports
NL5 Intelligent Charger port (charger available seperately)
Fused accessory outputs
Dimensions (L x W x H) : 500mm x 260mm x 300mm
 Keith
Post #916532 11th Aug 2021 7:54pm
chris h
United Kingdom 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
PM sent.
REGARDS
CHRIS 2009 110 SVX 60th Anniversary - Santorini Black
Post #918177 22nd Aug 2021 10:06am
Keith5
Provisionally sold pending collection Keith
Post #918538 24th Aug 2021 1:11pm
Chris Rogers
2013 Defender 110 Puma 2.2 USW Bonatti Grey
Can I be the reserve?
Chris 2013 Defender 110 USW
2017 Range Rover Sport SVR
2019 Mercedes X Class V6
Post #918707 25th Aug 2021 4:48pm
Keith5
Sold Keith
Post #919774 3rd Sep 2021 10:39am
