Home > Puma (Tdci) > BAS fault codes.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
BAS fault codes.
Just trying to familiarise myself with the BAS tool as I might need to use it on the way down to SA, have one fault code & noticed you can check the oil level?
It’s showing 128% but bang on the top of the dip stick, thoughts? Is anyone familiar with the fault code, from what I can gather it’s a sensor on the brake pedal which has redundancy?
Post #913966 25th Jul 2021 9:53am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
No Engine oil QTY sensor is fitted to the Puma.
Unfortunately the 128% is a ECU dummy value that’s meant to elevate your heart rate.
Post #913970 25th Jul 2021 10:14am
Timcat
Thank Christ for that!
Post #913973 25th Jul 2021 10:24am
