Home > Puma (Tdci) > Wipers
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
Wipers
I have noticed that the start and return points on the windscreen sometimes change, with both blades stopping short of the full sweep and then running off the bottom of the screen . Then after a few moments it returns back to the correct sweep on the screen . Could it be the motor is moving in its support ?
Post #904748 24th May 2021 4:03pm
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Quite a common issue..
More likely a worn drive cable which runs from the motor across to both blades..
Or can be the actual wiper drives at the base of each wiper.
You will need to take apart to know for sure.
Not an expensive repair...just a little fiddly.
Many write ups on here
Clemmo Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #904756 24th May 2021 4:57pm
ickle
Or in the motor drive itself, the circle falls off the pivot on the end of the crank arm and randomly changes park and sweep angles as the plastic bush moves....
Good luck!
Post #904761 24th May 2021 5:09pm
Howard
Thank you for your replies, I replaced the cable last year because it had snapped. At the time they didn’t appear any free play in the spindles, and I stripped and re greased the gearbox on the motor. I think I will replace the motor and spindles .
Post #904796 24th May 2021 6:44pm
