Home > Puma (Tdci) > One piece rear half shafts
trailbear
I have just received my new one piece half shafts and was wondering what is the current thinking
On fitting the gaskets. Long time ago it was the norm to slather gaskets with Hylomar / liquid gasket and the like or is it to fit them dry
Or with a slight smear of grease?
Post #903633 17th May 2021 8:00pm
Mdm
paper gasket or a thin smear of sealant is all you need
Post #903634 17th May 2021 8:03pm
trailbear
Yep, got the paper gasket, so it goes up dry?
Post #903640 17th May 2021 8:19pm
I tend to fit the paper gaskets with a smear of grease to hold them in place as much as anything. It seems to work as they don't leak.
More details here:
https://www.defender2.net/forum/post727193.html#727193 Darren
Post #903649 17th May 2021 8:57pm
Paper gaskets traditionally were always greased, it helps to stop them wrinkling.
Post #903656 17th May 2021 9:38pm
I did the same as the above two comments. Works well. Thumbs Up $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #903657 17th May 2021 9:42pm
trailbear
Ok, seems like thatโ€™s the way ahead then.
Thanks Gents.
Post #903660 17th May 2021 10:06pm
