![]() | Home > Puma (Tdci) > Check engine light after refueling |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2119 ![]() ![]() ![]() |
Welcome to the forum !
You would be advised to pop a code reader onto your engine management system to see what fault codes pop up and then take any action that is advised from there. It may be that the tank breather is an issue or that something coincidental has occurred while you were on your trip. Let us know what you find and we can give more advice from then ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 ![]() ![]() |
Left my fuel cap off recently, no warning light during a 30 mile journey. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
The engine warning light will not reset itself. A code reader is a vital bit of your defender survival kit. 99% of the time it comes on there is nothing to worry about. The reader allows you to wipe the stored fault codes which switches off the light.
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 554 ![]() ![]() ![]() |
Fault codes appear for some reason. Find out their meanings and check if they reappear...
I believe the user manual wants you to stop the engine if the engine light appears ... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
I doubt the MIL being put on the dash has anything to do with refuelling. More that a new ignition cycle was completed. I.e. shut off, then restarted.
As others have suggested. Needs plugging in and checking. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
