Home > Td5 > Rr springs on a td5
Busarider
Rr springs on a td5
Hiya guys replacing the suspension on my newly acquired td5 90...im been lead to believe rr classic are a good choice for road use... Anyone else running these springs... They'll be paired up with bilstein shocks
Post #893887 25th Mar 2021 3:38pm
Dinnu
See http://www.red90.ca/rovers/springinfo.html
The range rover had some of the softest spring. The column "Rate" in lb/inch is how much load is needed to compress the spring by 1 inch. So the lower the number, the softer the spring.
If you go for softer springs, you need to compensate in length (or use spacres) else, it will be sitting lower. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #893894 25th Mar 2021 4:10pm
jst
Rrc police spec springs were always the cheapest go to option for soft springs, slight height gain and great articulation. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #893897 25th Mar 2021 4:31pm
