Home > Td5 > Air in the fuel pump when first keying on... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
I would check around fuel filter head for moisture incase it has become porous, if not swap fuel filter for a very very high quality one incase yours is faulty or not sealed properly. The next step would be swap the fuel injector seals. Main dealer parts only.
6th Mar 2021 2:16pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
Did the rubber seal come off with the old filter or stay stuck on the filter head? 02' 110 TD5 Double Cab Rebuild Thread
6th Mar 2021 2:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8027 |
Does it start normally? Ie without priming on cold start Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Mar 2021 3:30pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Thanks all.
Answers to the thoughts... The filter head is bone dry and was working fine before I changed the filter. Rubber seal came off with the old filter and new one was on the new filter. Haven't really wanted to try cranking it till the air has passed round and got itself out each cold start in case it knackers the HP pump with insufficient diesel to lubricate it. But starts instantly once the air has circulated round and the pumps gone quiet. What's the thinking in each case? Does start/doesn't start? |
6th Mar 2021 3:59pm |
How much have you driven it since doing the filter? I find mine gurgles for a few days after changing.
Also there is no HP pump to worry about it, the TD5 has camshaft driven unit injectors. I find that even the extra fuel return pipe on the 15P head doesn't get rid of all the air in the fuel rail so takes a while for it to move through. Steve 02' 110 TD5 Double Cab Rebuild Thread |
6th Mar 2021 5:12pm |
