Home > Td5 > Sump removal
alexatnd
Sump removal
Hi sll,
It appears I've got a few leaks round the sump of my 1999 TD5.Thought I'd treat her to a new sump gasket.
How difficult a job is it?
Is there enough room to get the sump out without removing crossmember or jaclking engine up ?
Any Gotchas ?
TIA
Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #888690 2nd Mar 2021 7:36pm
htb2
Wales
Not a bad job to do, can be done in situ
Post #888704 2nd Mar 2021 8:08pm
rallysteve
I did mine a few years ago in situ. You will have to jack the front up about 8" to get enough clearance between the front axle and sump or it won't be able to clear the pickup pipe. The rear of the gasket is a swine to get the little pips on the gasket seated in the sump and rear of the engine.
Worth checking your oil pump bolt whilst there.
Mine ended up leaking just as bad as before i changed it, just in a different place! Rolling with laughter
Post #888721 2nd Mar 2021 9:15pm
souster4
I absolutely hated doing mine. Was really awkward trying not to get drips of oil in your eyes and down your arms. And awkward to get it over the diff. Really messy job I wouldn't want to do again in a hurry. I think I'd probably get a specialist to do that particular job. As the poster above says, lining the gasket up correctly is a nightmare.
Post #888743 2nd Mar 2021 11:35pm
HenrikSw
Sweden
gasket is the issue
Agree with the rest not hard job but messy, off is easy. The issue is the gasket, read that you could use plastic strips through the holes to get it aligned.....ended up clueing the gasket to the sump. If I recall it correctly you also needed to add sealant to a number of points as well (but I might be wrong on this). Not seen any Youtube clip on this maybe someone is ready for that?
Post #891510 15th Mar 2021 10:33am
geobloke
There is a decent write up here - http://www.discovery2.co.uk/Oil_pump_bolt.html
The job is not difficult, have done it two or three times now. It can be done with the wheels on the ground but is easier jacked up on axle stands.
When you buy the sump gasket don't forget the oil drain pipe has a metal gasket as well.
The key things are to keep everything clean and use a torque wrench. It is easy to create leaks by over tightening the bolts on these gaskets...
Post #892843 20th Mar 2021 6:00pm
