Home > Puma (Tdci) > screeching in one of the rear wheel
Eduardo
Hi there!
From some time ago I had a screeching in the left rear wheel (like the typical wear brake pad one) when I turn the car all left.
Some idea about what can be?
Cheers Eduardo
Post #88866 13th Sep 2011 12:12pm
It could be a stone/pebble or piece of gravel or grit in the brake. I've had this before made a hell of a screech. You can try and free it by braking and accelerating hard reversing and braking ect. Just a sugestion Thumbs Up
Post #88868 13th Sep 2011 12:21pm
Eduardo
Thanks Konabikes11,
That was my first thougth (and I hope that will be the issue), but the screech appears only when I turn left Question Question
Cheers Eduardo
Post #88870 13th Sep 2011 12:30pm
MK
Very same on mine. Brake pads in just one side. I have done everything to the pads: slots, cuts, etc. Next step is to swap pads from between tyres or skim the disc a bit. Puma 110" SW
Post #88871 13th Sep 2011 12:35pm
Grockle
try 'Copperslip' on the back of the pads 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #88894 13th Sep 2011 2:14pm
bob neville
Had the same problem a couple of weeks ago on Salisbury Plain - stone trapped between the disc and stone guard.
Guards are easy to remove so might be worth a quick check.
Bob
Post #88906 13th Sep 2011 3:37pm
So annoying especially when you can't free it very easily and you have to drive past people Embarassed
Post #88907 13th Sep 2011 3:43pm
Laurie
Fast reversing with sudden stop most-times dislodges stones.
Post #88967 13th Sep 2011 7:31pm
