Home > Puma (Tdci) > screeching in one of the rear wheel |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Hi there!
From some time ago I had a screeching in the left rear wheel (like the typical wear brake pad one) when I turn the car all left. Some idea about what can be? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Sep 2011 12:12pm |
Thanks Konabikes11,
That was my first thougth (and I hope that will be the issue), but the screech appears only when I turn left Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Sep 2011 12:30pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2415 |
Very same on mine. Brake pads in just one side. I have done everything to the pads: slots, cuts, etc. Next step is to swap pads from between tyres or skim the disc a bit. Puma 110" SW
13th Sep 2011 12:35pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
try 'Copperslip' on the back of the pads 2.4 90 XS
13th Sep 2011 2:14pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Had the same problem a couple of weeks ago on Salisbury Plain - stone trapped between the disc and stone guard.
Guards are easy to remove so might be worth a quick check. Bob |
13th Sep 2011 3:37pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
So annoying especially when you can't free it very easily and you have to drive past people
13th Sep 2011 3:43pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Fast reversing with sudden stop most-times dislodges stones.
13th Sep 2011 7:31pm |
