Home > Puma (Tdci) > ABS Pump ?
PMU
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
ABS Pump ?
When I start my 2008 110 there is a crunch when I coming from the behind brake pedal effectively, i have been told that its the ABS pump which is normal so just checking ?.
Post #871522 6th Dec 2020 7:43am
Johan H
Finland
mine has done it from new.
Cheers,
Johan
Post #871524 6th Dec 2020 7:55am
swt
Ditto. Same model year. If you start it with your foot on the brake pedal you can feel the pump operate.
Post #871672 6th Dec 2020 8:21pm
PMU
Thanks both, gives me a bit more comfort and yes I can feel if i press the brake pedal when starting.
Post #871764 7th Dec 2020 10:32am
