Home > Puma (Tdci) > Puma Front Prop Phasing |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17384 |
The photo below shows a totally unmolested and ex-factory 2007 Puma 110 front propshaft, along with a good one. You will notice that approx 45 degrees is correct, and this will be due to the fact that the flanges are not coplanar because of the upward tilt of the Puma engine.
Click image to enlarge |
27th Nov 2020 5:36pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I know the earlier vehicles had about 45degrees out of phase as well because the front final drive unit (commonly known as the diff) is not horizontal. But not sure if JLR increased the shift on front prop shaft due to the Puma being nose high. I made similar question, but on rear Puma shaft when I was new to my Puma. Only Puma have an out of phase yokes on the rear prop shaft, by about 45deg as well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
27th Nov 2020 5:53pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Excellent thanks. All good then. 2007 110 TDCi Station Wagon XS
27th Nov 2020 6:24pm |
