Home > In Car Electronics (L663) > Dash display lighting |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
Try the interior illumination switch, which is down by the park brake.
20th Nov 2020 4:58pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Thanks J,
I asked on another group and was told to bend down a bit further! It’s not exactly obvious and you have to press it in and when it pops out turn it to adjust! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
20th Nov 2020 5:44pm |
It seems a bit out of the way. |
20th Nov 2020 6:22pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Did it fix the issue?
20th Nov 2020 8:38pm |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
This illumination switch is not fitted to my Defender, I was convinced all the time.
Took a look again today. Magically it appeared... 😳 Last edited by Sepp on 21st Nov 2020 9:05am. Edited 1 time in total |
21st Nov 2020 6:26am |
Good morning Simon- I haven’t tested it yet, if it’s dark enough later today to trigger dusk/ night lighting I’ll give it a go. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
21st Nov 2020 8:55am |
Simon, it works in daylight but ............. it seems to have a fair bit of lag between turning the knob and dimming/ brightening happening. I’ll look after sunset again because I think that it was already on maximum brightness and that was really too dark even at night to see the info/sat nav screen between the dials. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
21st Nov 2020 11:39am |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 24 |
I have the same issue.
On a dark day, everything is very dim. The control dial is on maximum. Has been like it since new, so may be a dealer fix. Is the lux sensor in the centre front of dash? |
21st Nov 2020 7:34pm |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 175 |
Mine is now working correctly after 2.0.6 update.
14th Dec 2020 12:08pm |
I now have both screens dim at the same time but the brilliance control has very little effect. I can see a tiny change in intensity but it’s still too dark to read at dusk after the screens have dimmed. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
14th Dec 2020 12:16pm |
You still have your sun glasses on?
Any chance you you post some photos? |
14th Dec 2020 12:19pm |
When it's dark
Tried it again, back to not working Last edited by Philm on 16th Dec 2020 4:29pm. Edited 1 time in total |
14th Dec 2020 12:27pm |
Odd, the digital dash in my Velar has a black background and I’ve no issues viewing that at night. I would’ve thought the Defenders dash being blue would be more visible.
14th Dec 2020 3:55pm |
It’s not the dials but the info screen in the middle that is the issue
Thus is minimum brightness Click image to enlarge On Maximum Click image to enlarge Text is just as bad Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
14th Dec 2020 5:35pm |
