2003 TD5 - booming noise on acceleration
under part load in all gears I'm getting a 'booming' noise that i'm pretty sure isn't mechanical as it goes away higher up the rev range in each gear. Its very much a heavy bass sound.
It sounds like its from the exhaust / air intake as its more of a resonance boom related to air pressure, its where you would normally hear the turbo spooling up, but instead its a boom.
Changing down a gear and holing the same speed (e.g. 45 mph in 5th gear = booming, 45mph in 4th gear = no boom). Also if I dip the clutch it goes but that could also be related to lifting off the accelerator.
I've had a look round the car and can't see anything obvious, my 1st though is the waste gate?
7th Oct 2020 12:51pm
roel
Is your rear demper near the fuel tank bracket?
A few 1/2 ltr bottles of Grolsch will solve that problem.
Click image to enlargeRoel
2003 90 Td5 (2009-now)
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
