Home > Puma (Tdci) > Puma 2.2 2013 Immobiliser ECU burn
AT50HP
South Africa 2013 Defender 130 Puma 2.2 HCPU Alpine White
Would appreciate thoughts on causes
Events preceding
Wash engine with high pressure water gun.
Next day, trip from Centurion to Potch, ok
At Potch (5 hours after stop), no start
5A fuse melts when turning the key
(Immobilizer, fuse box under steering)
Get help from LR tech (gr8 guy)
Even blows a 30A fuse.
He decides to short circuit the fuse (I crynch)
Car starts, all good
Back home, I replace all fuses with spec
None burns, problem disappeared,
Except central locking on back doors dont work
And weak on the front doors
I have job pressures and decided to worry about that another weekend
Then
About 4 weeks later, I stop at my house
As I get out, I smell burning plastic
The neighbors are building and I wonder what they are doing
Pick up something in the house and get back the car
See smoke coming from the dash and hear that awful crackling burning sound
Rush, disconnect the battery
Some checking
No fuse were blown
No ECU error codes
Instrumentation seemed ok
No start. Just crank and then shut down
What happened?
Where to get a replacement board
Post #854864 8th Sep 2020 5:25am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Sorry to hear that. Maybe a short in the rear doors‘ wiring; the flexible part between door and B post?
They‘re directly connected to the ALM/AS10 with no fuses so could burn the ECU.
Post #854984 8th Sep 2020 3:05pm
AT50HP
Thank you - will afterwards fuse those lines- Appreciate
Post #855005 8th Sep 2020 5:09pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Are you sure that you need new alarm ECU? First try to remove the current one and look for burnt parts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #855102 9th Sep 2020 8:06am
AT50HP
Would be easier to look for unburned parts 🙂
Post #855232 9th Sep 2020 7:05pm
