Home > Maintenance & Modifications > Flatdog roof bars - fitting advice please |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Maybe you are over tightening them, causing them to twist? Not noticed mine pulling away.
They way I do it, and this may be wrong as I had no instructions either, is as follows: Set the feet in the gutters and make sure they up against the lip. Put the clamp in place and snug the grub screws up to hold them there. Put the nut and washers on tighten and them down until they are tight, but no need to swing on them. Give the grub screw a an extra nip up to make sure it won’t come loose. You might want to put electrical tape to protect the paint before you start. 2007 110 TDCi Station Wagon XS |
30th Jul 2020 6:33pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20371 |
I used 2mm neoprene rubber strips on mine before fitting which protects the paint and stops movement. They’ve been in place for about 6 years and never had a single issue. $W33T $0U7H3RN $UG4R
30th Jul 2020 7:06pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
When I fit mine, the angled mounting brackets are only lightly nipped up to the actual cross bar. The grub screws loose in their threads. I measure from a fixed point (front/rear corners) to ensure I'm placing each bar perpendicular to the roof gutter. I tighten each clamp onto the gutter using some old bicycle innertube offcuts to protect paintwork before I then fully tighten the gutter mount angle brackets to the cross bar. Finally I nip up the grub screws.
30th Jul 2020 7:34pm |
moleac Member Since: 04 Sep 2019 Location: West Sussex Posts: 6 |
Thanks everyone. Really appreciate the input.
I’ll try fitting again in the morning and now feel much more confident! |
30th Jul 2020 9:13pm |
