Home > Puma (Tdci) > Starting Problems
jbullis
United States
Starting Problems
I have a 2012 2.2, with about 21K miles. I haven't had it long, but the only way I can get it to crank is turn turn the key on. Wait for the glow plug light to go out(you try to start it then, nothing happens). I turn the key back off, then on and it always starts up. Whats going on, or what am I doing wrong?
I have also shot a video of this, if that helps...
Thank you
Post #839986 27th Jun 2020 1:14am
williamthedog
Check the tightness of the relays in their connectors under the seat. Thumbs Up
Post #839987 27th Jun 2020 5:22am
jbullis
United States
I tired the relays, they are all pushed in tightly.
Post #840062 27th Jun 2020 4:10pm
This thread may help:
https://www.defender2.net/forum/topic51335.html Darren
Post #840064 27th Jun 2020 4:18pm
jbullis
United States
I've been messing with it enough to determine that if I don't press the unlock on the immobilizer(if its not set), I have to go into the on then off again exercise. If I preemptions the unlock it fires on the first turn. Will changing the batteries in the FOB correct this? Or do I need to go into a different direction?
Post #840141 27th Jun 2020 10:33pm
Pat
Wales
Do you have a second fob? If yes, have you tried starting the vehicle with it?
I have one fob that starts my vehicle as it should and a second fob that only operates in a similar way to what you describe. I replaced fob batteries, tried re syncing the fob, but no change. Posted on the forum about this, but didn't get a solution. Tried a main dealer, but they wanted my 90 (MY 2012) in for investigation at their hourly rate, so I decided to live with a second fob that doesn't do what it should. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #840157 28th Jun 2020 6:36am
jbullis
United States
Good point. I only have 1 Fob. I’ll order another. I’ll also see if I can use the Nanocom to to reprogram my current Fob too.
Thanks
Post #840220 28th Jun 2020 12:51pm
jbullis
United States
After doing more research and messing with my Nanocom, in the 10AS, set the passive imbolize off. It fixed my problem. Help this can help others.
Post #840581 30th Jun 2020 12:47am
