![]() | Home > Maintenance & Modifications > Water Leak |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2191 ![]() ![]() ![]() |
No pic??
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 ![]() ![]() ![]() |
Hi The Shrink could it be the run off from you’re air con
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
What engine?
Are you talking about this drip? ![]() Click image to enlarge I would feel it a if it dose it feel oily? Does it smell? If neither I would then taste it. Coolant has a vey particular taste and condensation has no taste. |
TheShrink Member Since: 25 Apr 2019 Location: Somerset Posts: 47 ![]() ![]() |
![]() Click image to enlarge Yes you have spotted the drip which is coming from the area marked with an arrow. I put a bucket underneath to collect the water. It looks like plain water - not coolant and has no taste. I did notice that coolant is very low in header tank but I’m not sure this is related. If it was i assume what i collected would be coolant, which its not. Just makes no sense to me. I have taken it for a drive to see if that did anything and even afterwards it still dripped. I wish I was mechanically knowledgeable but really appreciate people taking the time to respond. Great website. Thanks |
Are you using your air conditioning whilst driving it?
If yes it will probably condensation on the AC condenser which is mounted with the cooolant rad, which is directly above those drips. |
I have air con but haven’t used it.
Odd. All I can say to help is, if it was any important fluid, it would taste, smell, or be oil.
Sorry I’m stumped, but will think on, and let you know if any ideas. Is this on a Tdci? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
The only other water in there that I can think of would be from the windscreen washer bottle and pipe work.
Thank you, Landy Andy - i appreciate it. It is a Tdci. |
