Home > Puma (Tdci) > Leak on passengers side mat
luke11
2008 Defender 110 Puma 2.4 XS DCPU Tonga Green
When i went to much truck this afternoon, (its been raining most of the day) i noticed a puddle in the middle of the passenger side mat, I had a look and it looks like its coming from the foot heater. I turned the fan on and even more came out, Is this normal? It's still under warranty so if it's a problem will arrange to get it fixed.
Post #83099 4th Aug 2011 6:39pm
RED-DOT
That sounds like the two drain nipples are blocked on the heater intake. Common fault. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #83103 4th Aug 2011 7:13pm
luke11
Are they easy to clear? Will save me the diesel and the hassle if i can do it quickly
Post #83141 5th Aug 2011 6:44am
Grockle
yes,access through he wing top vent,the teets are in the blower box the one at the rear needs an old 'Bic' pen top cutting down and inserting in the teet to stop it clogging up again,the one to the left (standing at the front) just needs clearing through. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #83144 5th Aug 2011 7:17am
RED-DOT
Mine had a few pints in there.. a stupid design but dont be tempted to remove and not replace them as i was as the heater fan needs a good bit of suction in the duct to work. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #83150 5th Aug 2011 9:15am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
If you don't have any luck with the heater intake nipples (that's what I started with), try the hinges for the bonnet.
I tried everything to cure the 'leak', including buying a snow-cover for the heater intake. It didn't work.
I eventually took the bonnet off (just lifts off with 2 people), unbolted the hinges, smeared a load of gutter sealant underneath and retightened.
Not had a drop of water in since!
Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #86360 27th Aug 2011 8:41pm
