Home > Puma (Tdci) > Leak on passengers side mat |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
That sounds like the two drain nipples are blocked on the heater intake. Common fault. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
4th Aug 2011 7:13pm |
luke11 Member Since: 10 May 2011 Location: Cambridge Posts: 32 |
Are they easy to clear? Will save me the diesel and the hassle if i can do it quickly
5th Aug 2011 6:44am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
yes,access through he wing top vent,the teets are in the blower box the one at the rear needs an old 'Bic' pen top cutting down and inserting in the teet to stop it clogging up again,the one to the left (standing at the front) just needs clearing through. 2.4 90 XS
5th Aug 2011 7:17am |
Mine had a few pints in there.. a stupid design but dont be tempted to remove and not replace them as i was as the heater fan needs a good bit of suction in the duct to work. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
5th Aug 2011 9:15am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
If you don't have any luck with the heater intake nipples (that's what I started with), try the hinges for the bonnet.
I tried everything to cure the 'leak', including buying a snow-cover for the heater intake. It didn't work. I eventually took the bonnet off (just lifts off with 2 people), unbolted the hinges, smeared a load of gutter sealant underneath and retightened. Not had a drop of water in since! One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
27th Aug 2011 8:41pm |
