![]() | Home > Wheels & Tyres > BF Goodrich KM3 MT |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20447 ![]() ![]() |
I had a set from Paddocks before, no problem. My most recent ones were from D44, again no problem.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17448 ![]() ![]() ![]() |
No pics yet because it was getting dark when I got home, it was a bit of a struggle getting them off/on my Blindos. I'll try to pics plus some impressions over the weekend.
The shoulders are very knobbly! |
Did the go on okay? When I had mine fitted they had a bit of trouble setting the bead. They thought it was due to storage most likely and a ratchet strap was needed to compress the tyre to set it. It worked in the end. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
They went on fine, but.needed one of those air-bomb things to seat them.
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 833 ![]() ![]() |
And they are on at last
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
Those look great BPS! Those blindos are 8” wide correct?
Any miles on them yet? How do they drive? 2014 Keswick Utility 2.2 |
7x16 et15 if I remember correctly with spacers
Only done a few road miles since fitting but compared to toyo Mts they seem to have a more flexible side wall and are a bit quieter. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2178 ![]() ![]() |
Anyone done a long or daily drive on these yet? How noisey? And vibration?
Anyone got a comparison to STT Pros? Considering a more aggressive tyre toward the end of the year, likely in 285/75 or 315/70. Instagram @defender_ventures Empire Tuning - Agent |
I've done about 600 miles since fitting mine a week ago, and have to say that I am still extremely delighted. They are so smooth, quiet, and comfortable compared to the high-mileage KM2s I took off. That includes a run to Devon and back (250 miles). Quieter than the old ones, no vibrations, and mine are presently not balanced at all because (a) my Blindos won't fit the balancing machine, and (b) even if they did I won't let them stick stick-on weights on my wheels. In due course I will stuff a load of beads in them, if it becomes necessary.
They also look the business, especially on Blindos. ![]() |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2168 ![]() ![]() ![]() |
What size rims and what tyre @blackwolf ?? Any pix
Looks great. 👍🏻 No Guts, No Glory.
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 319 ![]() ![]() ![]() |
What headlight protectors are you using? I like the look of them:-) |
Ive got Dynabeads on order as well blackwolf as I had the same issue with fitting on a balancing machine although they feel pretty good so far.
Danny Headlamp guards are eBay eBay Item No. 361460572892 |
