Home > Td5 > TD5 air filter housing mods.
portal pat
Australia 2001 Defender 110 Td5 SW Fuji White
I want to improve the air flow across my TD5 air filter. I can get inside the thing and start grinding plastic out as per previous posts or.............is it viable to fit a 200 or 300 Tdi jobbie instead? These units appear to be far more straightforward. Am I on the right track? Nothing suggests poor workmanship like wrinkles in the duct tape.
Post #815331 16th Feb 2020 5:23am
bankz5152
Just smack the impeller out with a hammer. Reseal the holes with some cut up 2L bottle and silicone. Td5 box is more than happy to let a TD5 fully breath at standard with that impeller removed.
Dont use a foam filter if you go off road. Stick to Gen LR Instagram @defender_ventures
Empire Tuning - Agent
Post #815357 16th Feb 2020 10:27am
portal pat
Thanks Bankz5152 but I have modded everything except a bigger turbo and that's to come shortly. So I am looking for more airflow than stock to feed that. Nothing suggests poor workmanship like wrinkles in the duct tape.
Post #815365 16th Feb 2020 11:04am
bankz5152
Heres my set up running a CRturbos hybrid, 4" hose running to a 3.5" snorkel.
Post #815371 16th Feb 2020 11:31am
portal pat
Thanks mate. Nothing suggests poor workmanship like wrinkles in the duct tape.
Post #815561 16th Feb 2020 10:46pm
