Home > For Sale & Wanted > [Wanted] Genuine 110/130 Springs |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I'd like to run standard, genuine springs (with air bag helpers on rear) and KONI HT Raid shocks on the 130, for the time being at least.
Does anyone have a set of new or nearly new take off springs to suit a 110/130? I believe the part numbers are as follows; Front Drivers - NRC9448 (Blue/Red) Front Passengers - NRC9449 (Yellow/White) Rears - RKB101111 (Purple/Brown) Thanks in advance. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
4th Feb 2020 3:13pm |
I must confess I know very little about the self levelling system...
Thank you for the offer, but I presume they won't be top to the task of supporting a fully laden 130. Unless of course someone knows different? 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
5th Feb 2020 8:54pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
Surely the air bags are there for the fully laden 130?
The purpose of the self-leveller is basically the same as the air-bags, it adjusted itself to compensate for the load in the back but via hydraulics rather than a manual air system. If the vehicle was empty then the springs provide the comfiest ride available, but the moment you put some weight on them then they drop down - but are meant to be aided by air bags or the hydraulic self-leveller. If you're always fully laden then not for you. Here's a pic of the 110 without any helper air bags - sits down quite low: Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
5th Feb 2020 9:06pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
The self adjuster was for County vehicles so they could have softer springs for on-road comfort. Utility vehicles just had stiffer springs. 130s have an inner helper spring. Some are being sold in this forum currently
6th Feb 2020 7:57pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
^^^^ Thanks for that mention!
I have some of the HD spring inners and outers on here for sale: https://www.defender2.net/forum/topic68103.html |
6th Feb 2020 9:01pm |
Having done a bit of reading I don't think the springs for self levelling will be up to the 130, but thanks for the offer! 1985 127 V8 Build Thread
7th Feb 2020 6:50pm |
