![]() | Home > Puma (Tdci) > Serpentine/ Drive Belt |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
You didn’t need to take the tensioner off. Careful use of a lever bar / crowbar will do it but watch fingers!
Bear in mind there are two belts, AC and Non AC. With the former being longer and the latter being shorter. I assume you have the correct one though anyway. On mine I found it was tricky to put back on, but ensured it was on all the way around except for the side closest to the brake master cylinder upper left. Ease the tensioner back, and you should be able to slip it back over keeping fingers out of the way. Be sure to check it is pull seated on all the pulleys before starting. Also bear in mind mine is non AC but the same similar principle applies. When you fit the tensioner back on, I believe there is a torque setting for it. Again, I assume you likely have it. ![]() ⛽️🛢️⚙️🧰💪 |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1231 ![]() ![]() ![]() |
Ahhhh..
yes I wish I had not taken the Tensioner off! pretty convinced its the right belt. ( Mines with Air Con) will re install tensioner and then try and slip belt on.... ![]() Cheers for advice and support Clemmo ![]() Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
