Home > Puma (Tdci) > Heated Rear Window
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Heated Rear Window
My heated rear screen has stopped working on my 2011 defender.
Before I get stuck in, are there any common problems to check first?
Kind regards
Kevin
Post #800582 3rd Nov 2019 1:16pm
dorsetsmith
fuses x2
broken wire in the rubber swan neck between rear door and the D post
Post #800586 3rd Nov 2019 2:26pm
Kevzeboy
Found this?
Post #800588 3rd Nov 2019 2:53pm
dorsetsmith
( found this? )
sorry do not under stand
Post #800593 3rd Nov 2019 3:28pm
Kevzeboy
Sorry, pictures didn’t go on.
Got it sorted. The main live to the relay connector was burnt out. Looks like it must have been a sloppy fit.
Sorted now.
Post #800597 3rd Nov 2019 4:42pm
dorsetsmith
add relay connector to the list Thumbs Up
Post #800604 3rd Nov 2019 5:08pm
Kevzeboy
Thanks.
Post #800994 6th Nov 2019 9:08am
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
In most cases the wiring on the window itself is not working anymore.
My Defender can only heat one stripe from the window and the 3rd brake light is not working due to this issue. I fixed the issue with the brake light and let the window as it is. I use the side mirrors in most cases anyway.
Post #801133 6th Nov 2019 9:30pm
bear100
Remove the 3rd brake light cover and you will probably notice the cover has worn away the track, a repair kit from Halfords for around £10 will fix the issue, I put on about 5 layers. It takes a day to cure
👍👍 [/img] 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #801140 6th Nov 2019 10:37pm
Kevzeboy
The front heated screen had about 100 mm that doesn’t heat in front of the steering wheel. Would no obvious brakes in the wires?
Any suggestions?
Post #801142 6th Nov 2019 11:14pm
The only fix for that is a new screen, I'm afraid. Darren
Post #801164 7th Nov 2019 8:57am
