Home > In Car Electronics > Auxiliary Circuit Building
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
I want to install spotlights, a boomslang type headlight loom, upgraded horn, Work lamp, additional camp lighting and power sockets. Looking for advice on planning the loom. I’m thinking of a positive bus bar in the engine bay with power from the alternator. Then a bank of relays to switch each of the new circuits. Is this a suitable proposal or would a connection in the seat box direct to the starter battery be better? And what about fuses? I realise I will need to fuse each additional circuit both the feed and the power to the component but what about the cable from alternator (or battery) to bus bar? Should that be fused too? Any ideas about best way forward would be most welcome, thank you.
Post #799327 24th Oct 2019 2:35pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If you are wanting the spots to activate in conjunction with your main beams after the fitting of the boomslang loom I simply used the now spare headlight supply socket to trigger the relay for them whilst taking a fused feed from the alternator. This kept all the circuit for the spots under the bonnet without having to add cables and switches into the cab. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #799329 24th Oct 2019 2:56pm
You definitely want any feeds from the alternator to be fused as close to possible to the source.
Bluesea do some very good bus bars that are well made and will last.
Especially with tinned lugs etc. (I've found Selterm there in the States to be very good).
If you wanted a better headlight solution I would recommend the Land Reiziger loom more than the Boomslang due to having two Relays.
One for the dipped, the other for main.
In mine I swapped the Relays out for Relays with a diode across the coil. (Check pins are correct, on mine the trigger and ground needed swapping around). TheThunder Rolls🇬🇧🇺🇸
Post #799353 24th Oct 2019 5:55pm
rockster57
Thanks Mash. That sounds a very neat solution Thumbs Up
Post #799390 24th Oct 2019 8:50pm
rockster57
Thanks for the info and recommendations Steve.
What’s the advantage of the diode equipped relays?
Post #799391 24th Oct 2019 8:52pm
I fitted a positive busbar in the rear of my USW to feed a variety of lights and sockets. I used an off the shelf busbar and mounted it in a plastic box:
The feed cable is from my second battery and is protected by a 60amp fuse:
Feeds from the busbar then go via a local fusebox to the various relays and switches:
I plan to do something similar, although on a smaller scale, at the front to provide a dedicated loom for the headlights Darren
Post #799400 24th Oct 2019 9:06pm
rockster57
That looks a very professional set up LRA! Food for thought! Much appreciated, thank you Thumbs Up
Post #799413 24th Oct 2019 10:27pm
rockster57
LandRoverAnorak wrote:
What are the blue components L1-4?
Post #799415 24th Oct 2019 10:33pm
They're latching relays. They're actually due to be swapped out at some point, as they don't work very well with the LR buttons that I'm using. It's the fault of the buttons rather than the electronics, though, but as I'm keen to keep the former another solution is called for Rolling Eyes Darren
Post #799434 25th Oct 2019 7:15am
rockster57
^^^ Thumbs Up Thank you
Post #799458 25th Oct 2019 10:13am
In answer to your question they (Diodes) across the Relay coil would help suppress voltage spikes or fly back voltage spikes up the power source wire. In a Relay they suppress and dissipate. When used in-line forward biased they voltage block return voltage.
Dissipation is better than blocking alone, and is better for relay coils longevity.
Particularly important with more sensitive electronic, as the return voltage spike could cause damage. TheThunder Rolls🇬🇧🇺🇸
Post #799468 25th Oct 2019 10:54am
rockster57
Comprehensive and understandable explanation. Thanks Steve Thumbs Up
Post #799472 25th Oct 2019 11:37am
rockster57
LRA, that bright metal plate? Is it stainless steel? And is it an earthing plate? Does it perform satisfactorily bolted to the aluminium wheelarch?
Post #799503 25th Oct 2019 5:08pm
It's a piece of aluminium and yes, it does provide an earth point. It's fixed to the wheel arch with a speed screw and so makes a very good connection. Darren
Post #799557 25th Oct 2019 9:38pm
keith
Very neat and professional job, well done Thumbs Up
Keith
Post #799559 25th Oct 2019 10:04pm
