Home > Maintenance & Modifications > Anti roll bar ball joint query
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi Chaps
I’ve sourced an early Front TD5 axle to replace my bent one on my TDCi 110.
The panhard rod bolts from the TDCi were bigger so I had to drill out the axle casing brackets. I thought that was the only modification required.
However I’ve got to the stage where I’m putting the anti roll bar back on and the ball joint tapers are a bit small for the TD5 casing and go too far into the socket , to the point where the thread is a hairs width from touching the radius arm .
As far as I can see there is only one type of ARB ball joint available NTC1888 or am I wrong ?
Any other solutions most welcome !
Rich https://www.instagram.com/hustynminepark/
Post #799196 23rd Oct 2019 5:29pm
Bluericky
Axle is all back together now and as I can’t get the front anti roll bar back on without welding on new brackets I’m just going to use It without .
Mine is a 2009 110DC in poverty spec and after some research they didn’t have an ARB fitted unless spec’d with alloy wheels ... which mine did until I sold them and replaced with wolf steels.
Still I have the back one so that should eliminate some roll ! https://www.instagram.com/hustynminepark/
Post #799483 25th Oct 2019 1:33pm
Interesting, my 2007 110 DC was county spec with alloys from factory but had no ARBs.
As far as I know the taper is the same size on all (and I think 1 in 10) so if your pins are loose in the hole shimming is the only option.
Post #799501 25th Oct 2019 5:02pm
Bluericky
Well that puts an end to the alloy theory !
I believe that post 2010-11 all defenders had ARBs as standard but then again I’m sure some left the factory without .
Is it possible to buy tapered shims anywhere , I have had a google and although they appear common in the U.S , they aren’t available in Blighty https://www.instagram.com/hustynminepark/
Post #799514 25th Oct 2019 6:08pm
