![]() | Home > In Car Electronics > park brake bypass |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1117 ![]() ![]() ![]() |
I have a clarion NZ502E , can anyone tell how to bypass the parking brake to enable the playblack .
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Try first grounding the green "PRK SW" or "park" wire usually light green in colour.
If that still doesn't work it will need this module, or at least it should do the trick anyway. https://www.amazon.co.uk/gp/product/B01L6Z...&psc=1 Obviously, you know not to use video features by law whilst driving but is good to have to be able unlock the features and also NOT. have to damage or add onto factory handbrake wiring. ![]() On some units without bypass you need to engage handbrake twice over every time you want to use certain features. ![]() Not to mention wire into factory wiring, not a fan. One of the two above options should work, try them in that order. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
many thanks Steve
Good luck.
