Home > Puma (Tdci) > Coolant woes! |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
there is more than one cap check you have the right one also is the thermostat working correctly if slow to open that could cause pressure in the system good luck
3rd Sep 2019 6:09pm |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 208 |
Definitely have the right cap, had several over the years! I think I’ll give the thermostat a try before going to the indy.
Thanks. |
3rd Sep 2019 7:53pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
I’d be checking the thermostat next, good luck hope it’s a cheap fix for you 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
3rd Sep 2019 7:55pm |
So, I’ve changed the thermostat and things seem ok so far. The temperature gauge comes up so much quicker than before and no expulsion of water yet! However, the bottom hose is still cold even after a run, is that normal?
16th Sep 2019 7:37pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
Is your water pump ok?
16th Sep 2019 9:55pm |
How would one tell?
17th Sep 2019 6:16am |
