![]() | Home > Puma (Tdci) > Coolant woes! |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
there is more than one cap check you have the right one also is the thermostat working correctly if slow to open that could cause pressure in the system good luck
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Definitely have the right cap, had several over the years! I think I’ll give the thermostat a try before going to the indy.
Thanks. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
I’d be checking the thermostat next, good luck hope it’s a cheap fix for you
![]() 2008 SVX 90 2000 XS TD5 90 |
So, I’ve changed the thermostat and things seem ok so far. The temperature gauge comes up so much quicker than before and no expulsion of water yet! However, the bottom hose is still cold even after a run, is that normal?
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Is your water pump ok?
How would one tell?
