Home > Tdi > Coolant system leak
Page 2 of 2 <12
donmacn
Jon, that's not the block itself but a big "bracket" onto which the alternator, water pump and power steering pump are mounted. Even then, I don't think it's cracked, I think it's a trick of the light with the flash.
Google 300tdi auxiliary bracket and the images will show you. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #790155 2nd Sep 2019 9:28pm
JonJop
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Thank you - was starting to think the water leak was the least of my worries!!
Post #790156 2nd Sep 2019 9:36pm
JonJop
Just to check on this chaos - I didn’t mention that the engine isn’t running when the water pours out. Is it still likely to be the P gasket?
Post #791064 7th Sep 2019 5:14pm
Balvaig
The p gasket tends to weep. If water is pouring out then I would still first suspect a split hose, then a fractured water pump and finally a crack in the block. You should be able to see a major leak like this. Try drying everything out before refilling.
Post #791084 7th Sep 2019 7:14pm
JonJop
Thanks very much. The hoses are definitely fine. I’ll order a new pump on Monday and will swap it out and report back.
Post #791085 7th Sep 2019 7:16pm
Balvaig
The other possibility is a corroded and ruptured core plug. More likely than than a cracked block. I didn’t think of it because they are more likely to rupture in freezing weather with no or weak antifreeze.
Not had one go on this engine so cannot tell you where they are but they will be on the block.
Post #791097 7th Sep 2019 7:59pm
JonJop
Thank you. I’ll try and locate it. The water is definitely coming from the direction of the water pump so there is a very good chance that the water pump and/or gasket is causing the problem.
Post #791108 7th Sep 2019 8:40pm
JonJop
Took the belt off this morning and can immediately see the problem. The top pulley wheel is very loose and the water pours from there. Looks like a bearing has gone so it’s definitely the water pump.
I’ve taken the self adjuster off and the top pulley but the lower pulley on the water pump is very tight. I’ll give the nuts a spray with duck oil in hope they will loosen up as I don’t want to break one off!
Post #791170 8th Sep 2019 11:17am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Put the belt back on. It will create more friction to help loosen the belt.
Also the angle at which you put the spanner determines the leverage on the bolt or the pulley.
Post #791172 8th Sep 2019 11:22am
JonJop
Sorry should have said, top pulley, tensioner and belt are back on but two of the 3 bits on the lower pulley are still locked solid.
Post #791177 8th Sep 2019 11:45am
JonJop
Two of the bottom three bits are now off but the third and final but has rounded off!!! Any top tips for getting it off? Has anyone used the Irwin tools for removing rounded heads?
Post #791193 8th Sep 2019 1:11pm
JonJop
Just a short note to say thanks for the advice. I changed the water pump, belt and tensioner today and the old girl is back on the road. After I managed to get the final bolt out the PAS pump pulley the job was a piece of cake.
Post #791869 10th Sep 2019 5:44pm
jfh
Glad you managed to fix her.
Post #791878 10th Sep 2019 5:53pm
Balvaig
Thumbs Up
Post #791943 10th Sep 2019 8:36pm
Zed
Glad you got it sorted.
Post #791947 10th Sep 2019 8:54pm
Page 2 of 2 <12
