Home > Maintenance & Modifications > What’s this part?
Grenadier
What’s this part?
Hello all. What is the pipe (NOT the sensor attached to the pipe) highlighted by the Number 4? I have a lot of oil sprayed around here and cannot work out where it is coming from. If anyone has an idea where the oil might be spraying from (seems to be underneath) that would be useful too. Thumbs Up
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #775077 26th May 2019 6:11pm
MarkGB
United Kingdom 2011 Defender 90 Puma 2.4 SW Indus Silver
Hi, it looks like it's the EGR valve tube:
https://www.lrworkshop.com/diagrams/land-r...ipes_45015
Post #775087 26th May 2019 7:04pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Someone had a simlar issue not to long ago and was talking about vaccuume seal/pump etc
Vaccuum pump (not turbo) leaking oil.
Post #775089 26th May 2019 7:21pm
williamthedog
More than likely it is the vacuum pump. It's in front of the area you've highlighted so a good chance the oils made its way back there. Thumbs Up
Post #775103 26th May 2019 8:12pm
kaney
My defender is in on tuesday for work on it but whist there the machanic is going to look at mine as i have this prob i hope rather than something more expensive but what annoys me is land rover or after market is silly money compared to ford ie
https://cdn.e-motiveonline.com/transitparts/images/logo.png
Post #775106 26th May 2019 8:29pm
Pipe number 4 in that picture is the extension to the inlet manifold that connects the manifold to the hose from the intercooler, the manifold to the EGR, and also holds the MAP sensor. It is common for it to be gungy. Oil on the outside may be from the vacuum pump, oil inside will have come from the breather system or turbo via the intercooler.
Post #775110 26th May 2019 8:45pm
Grenadier
Thanking you all. Will have a look tomorrow. Thumbs Up Monsieur Le Grenadier
Post #775120 26th May 2019 9:24pm
