Home > Td5 > Noticeable noise coming when driving above 60 km/h
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
I've recently had a belt snap seems like it was due to pulley bearing failure. After I had the car repaired. I've also noticed what may be front right side hub.. It sounds like something is not rolling right. I opened up the front diff to check the oil and it looks like the grease has leaked in from the Front hub. It's smells like grease and is the same color.
My steering also feels a bit delayed.
any suggestions? I will be rebuilding the HUB, the swivel and replacing the shocks. I do not like the mechanics around here so I will be attempting the work myself.
Post #771835 7th May 2019 2:49am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
With tyres that big have you jacked it up and checked the wheel bearing?? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #771837 7th May 2019 4:39am
dorsetsmith
noise sound like wheel beaning failing may sawtoothing i.e. tyres
Post #771842 7th May 2019 7:20am
