Home > Technical > 77k 2.4 lost power, back after Ign cycle
Page 2 of 2 <12
jst
could be, but in its defence.
Both times its happend in exactly the same place on the M5, after a drop before a climb. both times sat at 70mph on the drop, its gone in the dip. have driven the same route at lower speed 10 times or so between both occurrences, without it happening at 60/65mph.
tank was running on low (fuel light on) last week at same spot at 60mph it didnt do it. this is first time in my ownership that fuel light has come on, i was caught out! it don't generally run them less than 1/8th.
First time was 9/10th full of fuell
2nd time was 1/2 full.
would you still think fuel?
vehicles is filled from 1/4 to 1/8 empty every 10 days. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #764827 22nd Mar 2019 12:18pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
James did you get this sorted?
My turbo actuator does not move when gears are in neutral and engine is revved.
What did you spray into the inlet if anything?
Post #766054 30th Mar 2019 11:06am
jst
Having tried the fuel additive route I have some wynns turbo cleaner to add to the air intake. Just not got around to putting it in yet. Vehicle currently laid up. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #766096 30th Mar 2019 4:41pm
kmac
Thanks - also ordered the Wynns turbo cleaner - will use it tomorrow and report back on the results. Reviews indicate people have had mixed results.
Post #766151 30th Mar 2019 9:20pm
jst
Ok, interested to know how it goes. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #766186 31st Mar 2019 7:05am
kmac
Finally got round to doing this a few days ago. Too early to say if it has resolved the issue but a couple of shortish trips and has not gone into limp mode yet so fingers crossed. Also I did see the actuator move yippee.
Post #769424 20th Apr 2019 10:13pm
jst
Ok, I put the revive solution through it last Fri. Some muck out the back as it worked through, repeated the conditions, speed, duration, location and it didn't go to limp so fingers crossed, time will tell. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #769938 24th Apr 2019 9:10pm
kmac
Awesome, good luck
Post #769969 25th Apr 2019 7:14am
hank
I have experienced this https://www.defender2.net/forum/topic67122.html
Having scanned the ECU with my BAS tool it returned "P0234-00 ( 28 ) turbo overboost condition"
I spoke with Pete Bell whose response was as follows...
Sounds like the turbo is sticking slightly with heat after you have been on a run. Or the EGR valve is sticking open and you have not blanked it yet.
I’d advise checking the turbo arm is free by disconnecting the actuator arm from the turbo - I made a video a while back as this is a common problem
As seen in the video even when hot the arm should move very very free with your fingers when disconnected from the actuator. It should have no notchiness etc.
You are feeling the turbo variable geometry mechanism. If it’s notchy you may be able to keep moving it back and forth to free it. But as said it will be tighter regardless when hot. If you can’t free it then replace the turbo > 110 XS Double Cab
Post #769970 25th Apr 2019 7:15am
kmac
Was tempted to try this with the turbo actuator in situ but thought with my luck, if I tried to remove it, that spring link washer thing would fly off never to be found again...
Seeing how easily you removed it , will give it a try. The Wynns turbo cleaners does seem to have helped though.
Post #770029 25th Apr 2019 2:46pm
jst
Thank you, I did do this first and it seemed ok so exploring all avenues currently. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #770037 25th Apr 2019 4:03pm
Page 2 of 2 <12
