Home > Technical > TD5 - drivers electric window and door card - help needed
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
2005 Td5
Driver side electric window not working, fuse OK.
Removed door card this morning to find what appears to be plastic liner inside stuck on with mastic type adhesive. Is this usual?
Annoyingly broke the trim surround that holds the door lock latch - anyone know the part number for this and the little black firring that fixes door card to door?
In order to test to see if power is getting to the motor. It looks like will have to take the internal metal frame out?
Anyone got any help or experience of doing this.
Andy Defender Td5 XS90
Post #769438 21st Apr 2019 9:16am
rallysteve
Will put money on it being broken wires in the rubber convoluted tube which runs from the a-pillar to the door.
The plastic sheeting (water shedder) is original.
Post #769442 21st Apr 2019 9:50am
gilarion
Have a look here the photos and instructions may help you in taking out the metal frame
http://issuu.com/mobilecentre/docs/lrm_electric_windows For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #769449 21st Apr 2019 11:00am
Force64
Thanks for the help.
Quick power test and no reading.
Pulled the blue wire and hey presto!
Just got to replace blue and red wires now. Defender Td5 XS90
Post #769451 21st Apr 2019 11:25am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Just a tip. As a precaution also change the other thick wire.
And do not Just connect the 2 pieces. Insertie a new piece of wire through the whole rubber tube. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769456 21st Apr 2019 12:42pm
dorsetsmith
Paul Mc can sort you Electric Windows - Front Doors Connectors
https://www.ebay.co.uk/itm/DEFENDER-TD5-PU...XQTgZQ9~Ko
Post #769460 21st Apr 2019 1:49pm
Force64
Changed both wires and put back together except door card as waiting for a couple of fixings.
thanks for the help, Andy Defender Td5 XS90
Post #769483 21st Apr 2019 6:44pm
