![]() | Home > Technical > TD5 - drivers electric window and door card - help needed |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Will put money on it being broken wires in the rubber convoluted tube which runs from the a-pillar to the door.
The plastic sheeting (water shedder) is original. Steve 02' 110 TD5 Double Cab Rebuild Thread |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
Have a look here the photos and instructions may help you in taking out the metal frame
http://issuu.com/mobilecentre/docs/lrm_electric_windows For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Force64 Member Since: 02 Jan 2014 Location: Gatwick Posts: 196 ![]() ![]() ![]() |
Thanks for the help.
Quick power test and no reading. Pulled the blue wire and hey presto! ![]() Click image to enlarge Just got to replace blue and red wires now. Defender Td5 XS90 |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Just a tip. As a precaution also change the other thick wire.
And do not Just connect the 2 pieces. Insertie a new piece of wire through the whole rubber tube. a defender from 1984 pretending to be a puma with a touch of Range Rover |
Paul Mc can sort you Electric Windows - Front Doors Connectors
https://www.ebay.co.uk/itm/DEFENDER-TD5-PU...XQTgZQ9~Ko |
Changed both wires and put back together except door card as waiting for a couple of fixings.
thanks for the help, Andy Defender Td5 XS90 |
