Home > Tdi > No power from the alternator. |
Witch engine type TDI 200 , 300 TD5, TDIC 2.4 , 2.2 for the right wiring diagram
17th Apr 2019 6:22am |
From his vehicle icon, it looks like a 2.4. Darren
17th Apr 2019 6:46am |
but posted in Tdi
17th Apr 2019 6:57am |
Good point Darren
17th Apr 2019 7:00am |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 |
Sorry, 300 Tdi Defender, I also have a 2.4 TDCi. I think I found the problem, wiggling the exciter/power wires on the alternator checking voltage it works and then doesn't, looks like a poor connection.
18th Apr 2019 4:13am |
good news cheap fix
18th Apr 2019 5:24am |
I can't really complain, I bought it brand new 21 years ago and it's survived the worst Oz has thrown at it, and starts first crack of the key and uses no oil after 523,000km's.
18th Apr 2019 10:52am |
What I will be asking soon is which turbo option is the best, VNT or new cassette.
18th Apr 2019 10:54am |
Well just a heads up, no joy so far, I've even replaced the alternator and still get no voltage output. I don't understand actually because the brand new alternator has zero output even when I run 12V directly to the exciter plug. It's got me stuffed.
9th May 2019 10:41am |
Had alternator with the brushes jammed up in the holder stopping DC out put
9th May 2019 11:22am |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
During an engine swap on a 200tdi, Had built up a 200tdi Def block with all new ancillaries. Put it in, wired up and no alt charge. Put in a new loom, still no charge.Put in the old alt and worked fine. Could be a combination of a damaged loom in the first place, and a dead brand new Alt (possible, mine was at least a half decent Bearmach dead on arrival)
I would look at finding the pin out for your engine loom and run a temp cable from the multi pin and see what happens. If the alt won't charge with a direct feed put your old 'known good' alt on for the moment. |
10th May 2019 8:12am |
Well had some success today, I disconnected everything and just ran the original wire from the alternator to the battery and hey presto 14.2 Volts, I'd say my second battery, wiring or isolater is the culprit.
11th May 2019 5:00am |
