Home > Expedition & Overland > Storage ideas/Trailer help |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
If you fitted a receiver hitch like the Safari Equip one, you could very easily swap between NATO and normal tow ball. Or I think you could do something similar with the adjustable height Dixon Bate sliders, have two slider and swap them as required. 2007 110 TDCi Station Wagon XS
12th Apr 2019 7:49am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
I share your concerns on Nato hitches (I'm sure they're fine and many people use them but...). I therefore snapped up this trailer when I saw it for sale second hand. It just ticked all the boxes for what we wanted and we're very pleased with it. It does need quite a bit of weight in it to stop it boucing, but thats not normally a problem with our camping. It's great becuase all the camping gear lives in it so we just pack a bag, hitch up and go. The trailer was custom built for the original owner by Paranoid Industries.
Click image to enlarge Have you considered the MaxRaxx? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
12th Apr 2019 8:30am |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 739 |
I use an early narrow track Sankey which was converted to 50mm ball before I bought it.
I had some roof bars made for it and we’ve carried up to five bikes and camping gear all over the UK for Click image to enlarge the last 15 years with it. |
12th Apr 2019 9:35am |
Unless you need the rugged capabilities of the Penman, or you just really want one, then you'd be better off with a more regular box trailer. It'll be a lot lighter, easier to store and manoeuvre, and use a 50mm tow ball.
I appreciate just really wanting one, though Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Apr 2019 9:06pm |
The beauty of a Penman or Sankey is that if you stumble across a byway on your travels you can always have a detour, they were designed to be used off road 😊
12th Apr 2019 9:17pm |
pux146 Member Since: 30 Apr 2018 Location: Wiltshire Posts: 121 |
Thanks Gents for the replies, lots of food for thought to the point of even changing the Landy for something else.... 2007 2.4 90 fettled & remapped.
14th Apr 2019 10:17am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
The dixon bate sliders are my preferred solution, nice and easy to swap over! |
14th Apr 2019 12:24pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 |
I have a dixon bate set up with 2 slider plates --one with nato pintle and one with 50mm ball. 1 min job to switch over. if you get the penman it has auto reverse, and you'll need the nato pintle, backing plate with sadlles for the breakaway cable and if you're fixing the pintle directly to the cross member best to have a load spreader plate on the inside of the cross member 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
28th May 2019 7:10am |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
Got to echo the sentiment of the others, and using the dixon bate slider gives loads of flexibility.
Click image to enlarge Also means when not needed its a 10 second task to take it off and not have to continually straddle the hitch when reaching into the back The 50mm ball I've got mounted has a longer projection than the standard fitment though to avoid fouling the lower bar on the slide plate. Or a spacer behind the standard one would also work. Ref the Maxxraxx, I've just purchased one and tested it at the weekend. Initially my plan was to mount it beind the 50mm ball, but the slider plate fouled the angled web on the mounting plate, so I purchased another slider plate to fit and use it with that. Click image to enlarge Given mine is the 5 bike version, even if I figure out the mounting conundrum of fitting the nato hitch and maxxraxx mount together, the A frame wouldnt be long enough on the sankey not to damage at least one bike with the jockey wheel, and I'm pretty certain it would foul the tub as well. Could be configured to mount on the rear of the sankey perhaps? 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
28th May 2019 12:36pm |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 |
Hello pux146,
I had the same issues as you. I ended up building this trailer. I get 4 bikes, camping gear and boards too. As you can see I dont travel very light!!! You can never have enough storage space. Anyway, I 'm just in the process of painting the trailer to put it up for sale in the next week. Cheers Click image to enlarge |
31st May 2019 8:18am |
And I thought I took everything except the kitchen sink! Great setup!!
Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
31st May 2019 9:15am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
@rleslie... I see a kite buggy I had one that fitted perfectly across the width of an adventure rack
Cool trailer too, similar to one I saved a picture of for inspiration a few years back |
31st May 2019 11:43am |
Terribly photoshopped.
31st May 2019 11:44am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
I use a Thule bike rack if camping and taking bikes, fits 3 bikes folds down so you can get in boot.
We have camped many times with the 110 but now kids are bigger we need 4 bikes and with moving from site to site I'm fed up of packing just right so stuff fits in...even with a 110. So I'm literally converting my Sankey to camp trailer and Cary bikes😊 Just making a cover that folds up so with tailgate open and bikes in we can still access. No issue with NATO hook I have it on a separate drop plate can swap between normal towbar and this in seconds Click image to enlarge Click image to enlarge |
1st Jun 2019 6:14pm |
