Home > Puma (Tdci) > Master Light Switch
Montblanc
France 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Master Light Switch
I was driving through the 11km Mont Blanc tunnel yesterday when half way through my lights failed! I was able to switch to side lights but switching back to headlights - nothing.
Today I removed the master light switch and it appeared to have over heated causing the white plastic to soften so the contacts moved out of position slightly. I checked the current demand on headlights and side lights but nothing unexpected (about 9 amps and 3 amps respectively). I have ordered a new switch but I can't explain why the plastic melted. Any Ideas anyone ?
Post #767306 6th Apr 2019 9:56pm
dailysleaze
It's not uncommon to happen. It's partly the reason why people fit bypass/relayed looms, to avoid sending the full current through that switch and incurring the voltage drop
Post #767307 6th Apr 2019 10:03pm
grafty99
It's a very common problem. The switch is running at capacity with the standard headlights. It eventually fails. To solve the problem you need to fit relays to take the load off the headlight switch. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #767308 6th Apr 2019 10:05pm
grafty99
Beat me to it Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #767309 6th Apr 2019 10:05pm
Montblanc
Thanks guys.
That's great information, I just couldn't find a fault that would explain the failure so I was worried that I was missing something. I've ordered a new OEM switch and I'll see how it goes. Any further problems and I'll fit a relay kit.
Happy Land Rovering from the land of mountains and snow.
Post #767333 7th Apr 2019 6:31am
40 years design Neutral
Post #767341 7th Apr 2019 7:25am
Montblanc
Lucas... Prince of Darkness Smile
Character - that's what's missing in modern cars.
Post #767347 7th Apr 2019 7:37am
ericvv
Mont Blanc, get the Landreiziger loom too. It will not only avoid another switch failure in the middle of the tunnel, but it will also improve your headlights light production.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #767348 7th Apr 2019 7:48am
dorsetsmith
LRJ have mob puma 07 to 2011 re master light switch see link
https://1drv.ms/b/s!AtZSoWFHDgnGkjJVf5vaREsU7XKN
Post #767355 7th Apr 2019 8:30am
