Home > Maintenance & Modifications > Nolden headlight problem.. stoped working
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
I use the Nolden headlights since 2013 with great comfort.
Yesterday one of them started blinking and after 10 seconds it stops. If I put off the lights and turn them on again, the same story.. 10 seconds okay.. blinking.. stop...
Is this the end, or is there somthing I can do myself?
regards
Quirin
Post #763327 14th Mar 2019 7:51am
leeds
Is it the headlight causing the problem or the vehicle wiring causing the issue?
Either swop the headlights over and if the issue stays on same side then it is an issue with the vehicle.
Or take the faulty headlight off and with a new clean H4 connector try it on a fully charged battery.
I am not aware of any LED headlight being repairable.
My first thought would be a wiring issue or a connection issue.
Brendan
Post #763330 14th Mar 2019 8:01am
TopQ1967
Checked the volatage at the enterance of the headlight and it is normal without dips.
It seems like an internal (circuit) problem to me.
10 seconds okey
flickering and mainbeam comes in (5 seconds).
all lights out...
Anyone else had problems with the Nolden Headlights?
I have send Noldon an email, but they are not responding.
Lights are 4,5 years (50.000 km) old.
If this is it I am very disapointed. 850,- for a set of lights for such a short periode.
Post #765915 29th Mar 2019 9:38am
leeds
Have you tried swopping the headlights over?
Checking just the voltage is only a very simple test as a voltmeter basically draws no current.
What age is the vehicle? Is dim dip system fitted?
I have not heard of this type of problem before with Noldens.
Brendan
Post #765918 29th Mar 2019 9:53am
flyeffect
Ukraine
I have the same problem. Yesterday worked and today no longer.
Bought a pair in German Ebay a few months ago.
The work was about 20 hours in total.
I checked the power supply, swapped it with a working light. No sign of life.
I wrote to the seller, I wrote to Nolden - so far nothing.
It looks very high quality, but in reality is a little c Exclamation Question p.
I think to buy one JWSpeaker and install it in a pair with Nolden, at the same time I will test which of them is better.
Although there is no confidence in Nolden at all. Do not buy the Nolden.
Post #778800 24th Jun 2019 3:41pm
Not had any problem with my Noldens at all. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #778803 24th Jun 2019 4:08pm
