Home > Technical > Sumo bars & drop arm conversion.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Took the 110 (2.2 Puma) to have the tracking done & the ball joints / bars were solid! So rather than cremate them and try to get them moving I’ve took the plunge and gone stainless HD Sumo bars with drop arm conversion with grease able ball joints from Glyn Lewis ( we live in the truck for months at a time travelling) so it gets the best if something needs doing.
After reading all the paper work it seems quite straight forward ( if the oem drop arm & ball joints come apart that is) Question is has anyone done this & is there an easier method of doing this and any do’s & dont’s To concider? I’m not a mechanic but work hands on ( builder) Thanks in advance..
Post #760338 23rd Feb 2019 11:32am
Roy5695
Recently did this on mine. They are brilliant. I’d start soaking the drop arm securing nut in penetrating fluid.
You’ll also need a good puller to get it off too. I have the laser one I used to do mine. PM me if you’re interested in it 👍 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #760384 23rd Feb 2019 5:14pm
hank
Get the disc cutter out
 > 110 XS Double Cab
Post #760388 23rd Feb 2019 5:26pm
Retroanaconda
Sumo bars are a good upgrade.
Not sure I see the point of the drop arm conversion though for a normal vehicle. Maybe for a competition car which is wearing them out quickly.
Post #760394 23rd Feb 2019 5:38pm
Timcat
I know what your saying but for £50 pounds extra it covers everything & I’ve been told the replacement parts should it go in the future aren’t up to the original ones.
Post #760403 23rd Feb 2019 6:09pm
grafty99
I did the disco drop arm conversion when upgrading to sumobars.
Far, far easier to change the ball joint. Even if I only have to change it once it'll be worth the extra.
I hate the Swan neck ball joints Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #760410 23rd Feb 2019 6:39pm
Retroanaconda
No issues with genuine ball joints to my knowledge, though generally poor parts quality is an issue for everything eventually.
Changing the drop-arm ball joint is an easy 20-min job with the correct tool. And no need to re-adjust the drag link, or have an adaptor to mount the steering damper.
Swings and roundabouts really.
Post #760430 23rd Feb 2019 7:18pm
jst
i run the disco drop arm too with a TRE, its simpler to work on and easier to change a TRE than the std def drop arm ball joint in my experience. typically when the lip gets damaged on the std ball joint!
the only hard bit is getting the drop arm off the steering box.
you can measure the track rod length TRE centre to centre to give you a good starting point when fitting the new one. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #760435 23rd Feb 2019 7:24pm
sako243
The correct toll for removing the drop arm is a work of art. Popped around to a friend who had one and simply tighten it up on the joint and then whack with a hammer and it comes flying off.
Recently converted mine to a Gwyn Lewis drop arm (300Tdi 110) and it transformed the vehicle but that was largely because the other arm was loose. I got fed up of swapping ball joints, kept destroying gaiters off road and the lips would wear out meaning they kept popping off then.
Unfortunately only been on a couple of months and snapped two cranks so its off the road again so can't comment beyond that. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #760451 23rd Feb 2019 8:23pm
Roy5695
Video of the tool doing the job. Worked first time.
Instagram - @r22oyp
Roy
Post #760599 24th Feb 2019 6:40pm
