![]() | Home > Puma (Tdci) > Wheel Bearings |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
If I were you I'd ditch the spacer and revert to the old system, superior in almost every respect.
However the process for the old system is simply to fit and zero the end float, then pinch up the lock nut, recheck the end float and if correct stake the lockwasher. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
As above I would ditch the spacer, and stake nut system, and revert to the older twin nut setup.
But in reality if fitting good quality bearings the spacer you have on current setup will be the correct one. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Ditch the spacer!
