Home > Td5 > Any Nanacom One Experts ??
TJ101
Any Nanacom Experts ??
Def 90 Td5
Getting info to the unit, all good and when connected via USB , say "remote"
but tried to get it to talk to a laptop, and can't find com port , even tried a 2nd toughbook, and same issue
Any idea's,, ? Darn computers !!!!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #753235 22nd Jan 2019 10:13pm
landy andy
Been years since I had one, but, think I had to alter the port numbers on the laptop, as it wouldn’t allow connection to the usb sockets I had, or something like that.
Andy.
Post #753242 22nd Jan 2019 10:49pm
JWL
The menu button on mine isn't functioning and the way to connect to my laptop is to have the nanocom software up then plug the usb lead in and turn the unit on with the OBD socket, couple of in and outs seems to cycle the Nanocom into "No signal received etc" but if you leave it alone it goes through the initial start up on its little screen then pops over to "Remote" all by itself.
It doesn't make a difference on which USB port I use and I think that we've got so used to modern computerickery being quite swift that we easily forget that the Nanocom is Stone Age programming and is quite slow in comparison
Post #753253 23rd Jan 2019 12:35am
TJ101
Thumbs Up Thanks guys
I found it on the CF18 Andy,,, and renamed the comm port, got all the warnings, about other stuff won't work etc,,
gave it comm 6, when back in to program, selected com 6, still no good,,
Will try that way JWL,
LOL stone age,, Have one vehicle, that works on one up from Dos system !!! late 80's technology California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #753285 23rd Jan 2019 8:31am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
it's possible that the USB port on the nanocom is loose and getting data only from one way.
I had this before and changing the USB cable solved it. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #753646 24th Jan 2019 2:30pm
TJ101
Thanks
Serial out of unit to usb , will see if i have another cable,, as still not working,, either after renaming the com port again,, or having it plugged in, and powered the namacom up via the OBD California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #753657 24th Jan 2019 3:11pm
JWL
The cables are easy to source, they're computer to printer cables, that's where mine came from. I just used to pinch it out of the printer, life is so much easier now with a wireless printer Whistle
Post #753770 24th Jan 2019 9:43pm
