Home > Puma (Tdci) > Station wagon 07 Puma 2.4 idling problem...help please!
GeorgeTDI07
United Kingdom 2007 Defender 110 Puma 2.4 SW Indus Silver
My Defender is out of action for the second time in the last 12 months. The problem is that the engine wont idle. Nothing shows on diagnostics and nothing appears to be wrong with it.
Two Defender specialists have looked at the engine and neither have been able to resolve the problem. The following things have been check/repaired/replaced. ABS modulator, Switch speed control, EGR valve, gasket EGR valve, Reprogrammed EGR, remove/clean out fuel tank, fuel pressure valve (both), filter replacement, Hose fuel, Replaced injectors Sad reprogramming...amongst other things.
I have come across other people with the same problem but no one seem to have a solution. My next possible step could be to replace the high pressure pump but I have spent an eye watering amount of money already and there is nothing to say that this is going to fix the problem either....Any ideas anyone?!
Post #751187 14th Jan 2019 1:13pm
schuee
George,
A faulty VCV valve shows no fault codes, I had idle issues, especially when cold, so just replaced VCV and had it learned and all resolved Thumbs Up
Could be something else, though worth looking into.
https://www.defender2.net/forum/topic30222...t=vcv+idle
https://www.4x4community.co.za/forum/showt...trol-Valve
Keith MY2011 110 XS USW
Post #751193 14th Jan 2019 1:35pm
williamthedog
Yep as said above vcv your best bet Thumbs Up
Post #751195 14th Jan 2019 1:48pm
GeorgeTDI07
Thanks Keith, yes been there and replaced that!
Post #751197 14th Jan 2019 2:02pm
Caterham
it won't idle at all or idles very poorly?
did it suddenly happen or was it progressive?
Post #751207 14th Jan 2019 3:38pm
hornet
Re: Station wagon 07 Puma 2.4 idling problem...help please!
GeorgeTDI07 wrote:
My Defender is out of action for the second time in the last 12 months. The problem is that the engine wont idle. [...]
If it rotates but does not start, a faulty crankshaft- or camshaft-sensor (plug, wiring, seat, etc.) may be the reason.
Post #751393 15th Jan 2019 9:45am
GeorgeTDI07
It starts straight away but won’t idle. If you keep revs above 2000 it’s ok but as soon as you take your foot off the excelerator it cuts out. It came on gradually....we’ve checked all the obvious things and replaced lots of parts. It’s stumped 2 defender repair specialist, so it’s got to be something no one thought about....!
Post #751453 15th Jan 2019 2:34pm
Caterham
I see the egr has been replaced......does it definitely work correctly tho?
sorry not sure what else to suggest at the moment? good luck.
Post #751454 15th Jan 2019 2:37pm
Try replacing the clutch switch. $W33T $0U7H3RN $UG4R
Post #751456 15th Jan 2019 2:56pm
Caterham
sorry Steve,
not sure how that would help? I've disconnected the clutch switch and all it did was over rev / hang when changing gear as it doesn't reduce engine torq on clutch depress.
Post #751464 15th Jan 2019 3:19pm
Caterham
ah....
could it be switch is the problem ie the engine is constantly in reduced torq mode ie like having the clutch depressed all the time?
in which case simply disconnecting would confirm if that's the problem or not?
Post #751465 15th Jan 2019 3:20pm
It sounds very VCV-like to me. I'd almost be inclined to try replacing it again.
Post #751477 15th Jan 2019 4:16pm
MK
Not sure if I am just adding noise, but what about gas pedal sensor? Puma 110" SW
Post #751487 15th Jan 2019 5:29pm
Blackwolf could well be right, the symptoms are there.
Regarding the clutch switch, no you cannot just disconnect it on a Puma. Either replace the switch and re-connect or bridge it. You cannot just unplug it, it will not run correctly at all like that. $W33T $0U7H3RN $UG4R
Post #751512 15th Jan 2019 7:00pm
landy andy
Did you get your VCV programmed via the learn process?
Post #751547 15th Jan 2019 9:17pm
