![]() | Home > Off Topic > Any auto electricians on here? Strange issue |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Is there any reverse wire connections made in the head unit wiring on the vehicle side?
It could be grounding out and shorting the HU out. Multimeter will be your friend, see with all power shut down if there is any ground paths present where there shouldn't be I.e in live feeds. Obviously shut the complete power down and isolate first. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Every time i changed a headunit ive had to swap out the central fuse for that system. I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
